Working on a technique to raise wire antennas using an FPV drone. First, a mason line is tied to the drone and the line is set up on the ground so that it can be easily pulled up as the drone rises.
Next, the drone is flown over the desired tree and the power to the drone is stopped
After the drone falls to the ground, the line is used to pull up a heavier rope which is attached to the antenna. And the antenna is then pulled up to position.
It works very well!
